Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 02-27-2011   #1
Aurora40
Aurora40's Avatar
Default Anyone within WAZOO area limits want a Samco intake duct?
I'd like to sell it to someone who can try it out first, as the fit of these things is less than perfect. So you can be sure the fit is good enough that you are satisfied with it.
$75
Here's a shot of it on my car, and also you can see the fitment to the airbox:
Bob Saveland
Former owner of #2517
Old 02-27-2011   #2
Scrrem
Scrrem's Avatar
Default Re: Anyone within WAZOO area limits want a Samco intake duct?
Bob,
I'd be interested. PM me and we can work out the details.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 02-27-2011   #3
Aurora40
Aurora40's Avatar
Hopefully it'll fit up better than that water pump!
Bob Saveland
Old 02-28-2011   #4
Aurora40
Aurora40's Avatar
Man, don't plan a picnic on any days that Rich and I meet up! Always seems to be bad weather.
Good seeing you today Rich, and let me know how the duct fits up.
Bob Saveland
Old 02-28-2011   #5
Scrrem
Scrrem's Avatar
Yeah, need to meet in the summer. Well, got it on but man fit is really bad, did it arrive from Samco that way? It really was cut short. My concern is the damn thing coming loose at the air horn while going down the road. Maybe I can find another use for it.
Rich
Ron Davis Radiator
Old 03-01-2011   #6
Aurora40
Aurora40's Avatar
Does it fit worse than in my picture? You have to sort of "center" it between the air horn and airbox to get it on both with reasonable engagement.
And no, it comes from Samco so long that it bows up and lifts the airbox assembly. You absolutely have to trim it the way they deliver it. Which I did.
Let me know if you want your money back for it, it's no problem.
Bob Saveland
Old 03-01-2011   #7
Scrrem
Scrrem's Avatar
Yeah, I did a quick test fit last night. I'll work with it more this weekend see if I can get even between the airbox and the air horn.
Rich
Ron Davis Radiator
Old 06-23-2011   #8
HAWAIIZR-1's Avatar
Hey Bob,
Just curious to know if it was difficult to get a straight edge when you trimmed it. I know what you mean about it being almost 1 inch to long and I finally had trouble with mine interferring with the the A/C compressor when the clutch engages. It burned some and also hit the clamp, but mostly due to the air intake I have and difficult to get good adjustment. I'm going to yank off the intake filter system and put on the SLP claw as it fit and mounts well, I just have to trim off about 1/2 inch it seems so there is not so much excess and to cut the damaged edge that hit the compressor.
I thought of adjusting the clamp where I want to trim and using it as a guide with a blade to get a straight edge. You're the only one I am seeing mentioned trimming so looking for advice if you found what works to trim.
Thanks!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 06-25-2011   #9
Aurora40
Aurora40's Avatar
That's what I did, I used the clamp as a guide. The edge was pretty straight, at least appearance-wise. It can still end up being crooked in that the bottom is shorter or longer than the top of it. Though I think if it's totally even, it still can end up crooked when installed, as there is an angle between the air horn and the air box.
It's basically a big pain. So make sure it's really pissing you off enough that you just have to trim it...
Bob Saveland
Old 06-25-2011   #10
HAWAIIZR-1's Avatar
Thanks Bob! I'll measure twice and cut once if need be. I noticed it is best to trim a little from both side if true even is desired. I'm going to test fit the SLP and see how much difference from the other cold air one that is a pain to get lined up right. I know what you mean about the SAMCO and if my stock one with the stiffener was not in my long term storage while overseas I would put it back on. It is quite thick so I was not sure how it would do cutting with the xacto blade or one of those other cutters that you can break off new blades. Thanks again for your input.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
