Old 02-26-2011   #1
phrogs
phrogs's Avatar
Default need a part number for the power steering return line
The one from the cooler to the steering rack.
Soft line going into a hard line clamped ends
JOHNNY P
Currently own
Old 02-27-2011   #2
Default Re: need a part number for the power steering return line
90 - 91 P/N 26016988
91 - 95 P/N 26033592
This is from the parts CD that Kurt burnt. The P/N's are old numbers that have proly been changed?
Also, according to the CD you can't get just the hose you reference. It has N/S where the P/N would be, I figure that means No Stock? The numbers I listed are a package with that hose & the clamps & a nut.
I just tried the P/N's @ GM direct and it seems that they are NLA.
Old 02-27-2011   #3
ittlfly
You might give O' Rielly's or NAPA a call with that part #. They both were able to cross reference it to after market parts stock for me when I was working on another problem.
1994 ZR-1 # 0102...SOLD
ittlfly is offline   Reply With Quote
Old 02-27-2011   #4
phrogs
phrogs's Avatar
humm.
What about the demensions?
Length, outisde and inside diameters?
JOHNNY P
Currently own
Old 02-28-2011   #5
HAWAIIZR-1's Avatar
Johnny,
I took mine to a hydraulic hose shop when I could not find the hose and they just cut off the connector and gave me a hose and clamps. They told me it would cost more than worth to make a hose and since low pressure no issue; it was worked fine since. Not the NCRS solution, but works great.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
