![]() Join Date: Aug 2008
Im very happy with the work the body shop did but I noticed the car was running kinda rough when pulling out of the body shop. And almost didnt run at all when starting it up to leave work. So natually I pulled the codes when I got home. H32 34 36 38 74. I suspect all the codes in the 30's are banks. Just don't have an SFM to confirm it.
Any chance they blew off the map sensor hose?
Nope that's the first thing I checked.
![]() Join Date: May 2008
Code 36 indicates a direct ignition system circuit fault.
ZR1 ECM CODES 1990 TO 1992:
Code #12: Normal No Codes. Code #13: Left Oxygen Sensor Circuit. Code #14: Coolant Temperature Sensor Circuit High. Code #15: Coolant Temperature Sensor Circuit Low. Code #16: Direct Ignition System (DIS) Fault Line Circuit Code #21: Throttle Position Sensor Circuit High. Code #22: Throttle Position Sensor Circuit Low. Code #23: Manifold Air Temperature Sensor Circuit Low. Code #24: Vehicle Speed Sensor Circuit. Code #25: Manifold Air Temperature Sensor Circuit High. Code #31: Camshaft Sensor Circuit. Code #33: Manifold Absolute Pressure Sensor Circuit High - Low Vacuum. Code #34: Manifold Absolute Pressure Sensor Circuit Low - High Vacuum. Code #36: Direct Ignition System (DIS) Circuit (missing or extra EST signal) Code #41: Cylinder Select Error (Faulty or Incorrect Mem-Cal) Code #42: Electronic Spark Timing (EST) Circuit. Code# 43: Electronic Spark Control (ESC) Circuit. Code #44: Left Oxygen Sensor Circuit Lean. Code #45: Left Oxygen Sensor Circuit Rich. Code #46: Vehicle Anti-Theft System (VATS)(PASS-Key) Circuit. Code #51: Mem-Cal Error. Code #52: Engine Oil Temperature Sensor Circuit Low. Code #53: System Voltage. Code #54: Fuel Pump Circuit (Low Voltage) Code #55: System Voltage Code #56: Vacuum Sensor Circuit. Code #61: Secondary Port Throttle Valve System. Code #62: Engine Oil Temperature Sensor Circuit High. Code #63: Right Oxygen Sensor Circuit Open. Code #64: Right Oxygen Sensor Circuit Lean. Code #65: Right Oxygen Sensor Circuit Rich ECM 31 LCD Data Circuit-Circuit shorted to battery voltage or CCM driver open 33 Data Clock Circuit-Circuit shorted to battery voltage or CCM driver open 35 Data Strobe Circuit-Circuit shorted to battery voltage or CCM driver open 37 M Clock Circuit-Circuit shorted to battery voltage or CCM driver open 72 LCD Dimming Open Circuit-Circuit open or shorted to ground (radio & Climate control) H History code. May be intermittant. Code 31, 33, 35 related to the circuit from the CCM to the Instrument panel LCD. CCM 74 is also a lighting circuit problem. CCM 41 is loss of communication with the ECM.
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 02-15-2011 at 11:15 PM. |
As soon as this happened the first thing that came to mind was that I have been having a coolant leak thats been draining out the valley drain tube on to the floor. When I put the top end back together a year ago I noticed the drivers side injector housing to head gasket had a cut on it all the way through one side. But I figured if I put some 518 on it and torqued it down it would be ok. But if its leaking a little coolant into that cylinder than that could cause this to. I'll pull the spark plugs on that side and take a llok at them. I've got no choice. I have to pull the top end off to see where this leak is coming from and just fix it. And this may have nothing to do with the way its running. It may just be coincedence that after I got it back from the body shop my radio is dead and all these codes popped up and the car runs the same way as they do when the map sensor is unpluged but not near as bad as when the map sensors unpluged.
could it have dropped a coil pack? Maybe a plug wire is loose? Dont forget to check the easy things first.
Radio dead too? Sounds like a bad fuse or ground. If you ahve a FSM you might check to see what else is on that circuit....or a common fuse/ground.
#9 |
About 6 months ago my dash display with the tac/speedo light would get bright then really dim and sometimes the radio would pop and crack but not often. I always check the easy stuff first. But for this to just happen all of a sudden. But a coil pack can go out all of a sudden. And so can an injector so we will see.
#10 |
![]() Join Date: Jan 2006
Free to check---> I would check that all grounds are tight.
Ted |
