![]() Join Date: Jun 2005
What year shocks can be interchanged between ZR-1s. I may need shocks and looking to swap some out. But curious which ones will fit my car/actuators. My car is a 1990.
Thanks. |
#2 | |
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 02-02-2011 at 04:01 PM. |
#3 | |
![]() Join Date: Aug 2006
Give them a call. They may sell individually also. http://www.shox.com/appguide/shoxsho...ctsdisplay.php You were not quite clear as to why you are thinking of replacing them. Shock worn out due to mileage/years or throwing codes? |
![]() Join Date: Jul 2007
if you buy 92-95 FX3 shocks you would also need the 92-95 FX3 controller as well
Unless you replace the top gear to the earlier options. Yes
I am not so sure. Based on the part number for Shox.com, 90-95 list the same actuator.
Note the stop lengths are different but the gear itselef is the same. |
correct the actuators are the same
The actuators are the same for all FX-3 equipped cars from 1989-1995. The top gear is the only change to the shock. If your 92 and up FX-3 car commanded the actuators with 89-91 shocks on it without a top gear change the actuator would command a long ertravel than the top gear would allow until it eventually breaks all the nylon gears and ultimately timing out on all for corners. Unless you change out the top gears and the FX-3 controller box.
#9 | |
#10 | |
Correct, but the 89-91 shocks are readially available so thats the COA I would advise.
