![]() Join Date: May 2008
Jerry,
I noticed that you've added another new product...Permabond A136. I don't have an immediate need for it, but wanted to add it to my stash of stuff for when I get around to re-building my spare '94 LT5: 1) do you think the 50ml bottle will do a complete engine...not just the cam covers? 2) I think the book calls for about 3-4 different types of assembly adhesives...is A136 a suitable alternative for all of them? 3) do you happen to know the shelf life of the product? This stuff is virtually impossible to find at reasonable prices & usable quantities (single engine projects)...thanks for locating it and making it available. Thanks for continuing to be an affordable alternative for LT5 parts/products. |
#2 | |||||
![]() Join Date: Dec 2003
You can also use Loctite 518 as a substitute for Permabond A136. I'm going to use 518 on my LT5.
But it is nice to have the original A136 now available for those that want it. |
I've used the Threebond 1194 that's used for jap motorcycle engine case/transaxle sealing. Seems to seal well, based on my admittedly little experience.
I think the very most important charateristic of the material used for cam cover sealant is "non-shimming effect". Choosing an anerobic sealant to keep oil from leaking is one thing, but not the most important. The journal bearings for the camshaft are machined directly into the cover & cyl head. If the sealant used has any shimming effect, it will open up the journal clearances and all manner of bad things could happen, none of them good.
Choose wisely grasshopper, it aint just about huckey -puck. We offered Loctite 518 because it was about the only anerobic sealant besides Permabond A136 that had any real track record. We are going to discontinue offering Loctite 518 just as soon as the Permabond A136 is in stock. I know A136 works and works right.
#6 | |
Great info, Jerry. I know I had read somewhere (maybe even on this forum) that others had used the Threebond successfully. It goes on very thin, unlike an RTV sealant, so it seems like any shimming effect would be negligible. Maybe next teardown I'll reconsider, or not ![]() |
![]() Join Date: Jan 2010
What's the shelf life on an opened bottle of A136?
