I've now bled my brake system 3 times - including bleeding the master cylinder prior to bleeding the 4 wheels, as per the FSM. The pedal sinks right to the floor when pressure is applied. I figure the Master is leaking internally, though I've disassembled it and can find no obvious defective seals. I see rebuilt units for $150-$200, and am tempted to go this route rather than rebuild my original unit. Keep in mind this is the original '91 master cylinder, with 188k miles on it. Comments?
Update: ordered a Dorman from RockAuto, for around $160. Will update when I receive part.
![]() Join Date: Jan 2006
Who can rebuild them? I dont think ZFDoc does anymore
Update: Dorman part is not in stock, 2-3 week backorder. Next available part was $200+, so I am going to try my luck with the Cardone rebuilding service. I have to send in my master and they rebuild it. Not much to lose for $60, comes with 1 yr warranty.
![]() Nope just the clutch cylinders and salves cylinders from time to time
#6 | |
#9 | |
![]() Join Date: May 2008
Let me know if i can help. I'd probably rebuild it though, when I bought those parts they were pricey. Hundreds each not $60. How can you go wrong with a 1 year warranty? Last edited by xlr8nflorida; 01-05-2011 at 01:26 AM. |
#10 |
Pedal to the floor as well. Usually you hear a vaccum type hiss at the booster while pushing down at the pedal unless the diaphram has completely blow out that is. With that many miles I would replace the master just for GP
