![]() Join Date: Apr 2007
I have a oil leak on the passengers side of my 91 ZR1, when I start my car there is a oil burning smell. The car sat for 6 mo & there is a fair puddle under the car. I don't know if the cam covers have a gasket in them or not, if so is it a big job to replace .TIA.
lorne #1748
lorne # 1748 Stock except for a modified Corsa exhaust. When the flag drops the bull sh1t stops! |
other things it could be is the oil pressure switch,either the top one or the one thats a pia to get to on the bottem side of the oil filter housing or the oil filter housing gasket itself as well as the lines to the oil cooler . you need to take your time with a good light and you should find it .oh one other common area is the oil pan bolts have a tendancy to be loose .hope this helps
![]() Join Date: Mar 2008
I'd suggest starting with a check of your exhaust manifold studs Lorne.
A common issue with a simple fix - check item #20 here: http://www.zr1netregistry.com/ZR1_issues.htm#20 |
My bet is on the Oil Cooler Hoses.
Check where the metal portion is crimped to the rubber part of the hoses. If your finger comes away wet, there's your smoking gun. TomC 'Crabs |
this
![]() Join Date: Jan 2007
Sounds like oil cooler hoses to me. I had the exact problem. Good luck changing them. I don't there is any way you can change those without making a mess, no matter how many rags you use.
![]() Join Date: Aug 2006
Thanks everybody I'll check the oil cooler lines first. Are the lines available from GM or does someone sell hem on the forum. lorne #1748
lorne # 1748 Stock except for a modified Corsa exhaust. When the flag drops the bull sh1t stops! Last edited by hiperf406; 12-28-2010 at 12:40 PM. |
#9 |
NLA at GM but Jerry has them: http://jerrysgaskets.com/store2/root...b684ee0e812e25
#10 |
Checked cooler lines & filter neither show any sign of oil leaking. Will check oil pressure senders as I have noticed my oil pressure bouncing around. lorne
lorne # 1748 Stock except for a modified Corsa exhaust. When the flag drops the bull sh1t stops! Last edited by hiperf406; 12-28-2010 at 01:16 PM. |
