View Poll Results: Which battery do you have in your ZR-1?
AC Delco 115 45.63%
Autocraft 4 1.59%
EverStart (Wal-Mart) 14 5.56%
Exide 5 1.98%
Kirkland (Costco) 2 0.79%
Interstate 26 10.32%
MAXX 3 1.19%
NAPA 4 1.59%
Nascar (Sams Club) 1 0.40%
Optima 30 11.90%
Sears Diehard 14 5.56%
Bosch 5 1.98%
Duralast (Autozone) 21 8.33%
Odyssey 6 2.38%
Braille 2 0.79%
Voters: 252. You may not vote on this poll
Old 01-17-2006   #1
Z Factor
Z Factor's Avatar
Default Which 12V Battery Do You Have Installed?
What battery do you have in your ZR-1, and are you satisfied with it? Why did you chose it, and if you will be switching to a different one when the time comes, why?
Is the one you have not listed in the poll? If so list it here and I will add it.
Old 01-18-2006   #2
Default Re: Which battery do you have?
Exide
Tom is offline   Reply With Quote
Old 01-18-2006   #3
Z Factor
Z Factor's Avatar
Originally Posted by Tom
Exide
Thank you, it has been added.
Old 01-18-2006   #4
RICKYRJ1
RICKYRJ1's Avatar
You left out a dead one. That is what I have 1 vote for me
Old 01-18-2006   #5
One car has A/C Delco
The other car has an Interstate
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 01-19-2006   #6
Nick
Kirkland Signature by Costco. Why not have the best?
Nick
ZR-1 Net Registry Founding Member #32 - lapsed...
Old 01-19-2006   #7
Z Factor
Z Factor's Avatar
How I could have left it off of the poll is a mystery, but it is there now, so you can put your vote in.
Old 01-19-2006   #8
40th#381
WallMart Everstart
40th#381 is offline   Reply With Quote
Old 01-19-2006   #9
bobbyhi
bobbyhi's Avatar
Interstate in my Z..............
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 01-20-2006   #10
Are you only interested in the battery currently in the car for the poll. I have had my car long enough that it is on it's fourth battery. The origianl AC battery case split vertically along the centerline on the terminal side dumping acid which required disassembly of the battery box area, cleaning and repainting the frame, and cleaning the ground connections to the frame. I replace it with a Diehard, next came another AC, and currently the Exide standard battery. Exide also makes a spiral cell battery similar to an Optima at about the same price as an Optima.
