Old 12-20-2010   #1
Locobob
Default Some "Dynomite" Heads!
Just getting started on Dynomite's head porting so I thought I'd share as I go along. Some interesting measurements from the stock (untouched) heads:
Combustion Chambers came in around 41cc with not much deviation, this was using my own method and a spark plug in the hole.
Intake runner dimensions:
Diameter at IH gasket surface: Primary 32.3mm, Secondary 36.4mm
Diameter, narrowest point of runner: Primary 32mm, Secondary 32mm (just upstream of valve guide)
Runner width at valve guide: Primary 33mm, Secondary 33mm
Valve seat diameter: Primary 34.7mm, Secondary 34.7mm
Exhaust port dimensions:
Valve seat diameter: 32mm
Width across valve guide: 34.8mm
Runner narrowest point: 31.5mm (where ports merge into one)
Header gasket surface: 51.8mm long, 35.6 tall
Robert
Old 12-20-2010   #2
Locobob
Default Re: Some "Dynomite" Heads!
Some close ups of the chambers:
The worst areas are hard to see, sharp edges and poor transitions an inch or so above the valve seats.
Robert
Old 12-20-2010   #3
Locobob
Looking down the intake runners:
It would appear from the measurements I made that the two runners are mirror image castings with only the machining done to the top of the secondary port differentiating them.
Exhaust ports:
Here is the template I made off the bottom of the injector housings which I had enlarged only slightly. You can see just how skewed the port alignment is from the factory. It is noticeably worse on the primary runners, secondaries are closer probably due to the machine work done on these.
And marked on the head without the template
Robert
Old 12-20-2010   #4
mgbrv8
Excellent work Sir, keep the pictures coming.
Old 12-20-2010   #5
Polo-1
are those the fire sale heads
Old 12-20-2010   #6
Kevin
Kevin's Avatar
glad to see your heads getting some love
Old 12-21-2010   #7
( insert wolf whistle here ) It's nice to see your car getting some head work dunn
Old 12-21-2010   #8
Great pictures Bob. When I first started making gaskets, I used LT5 engine drawings & made them to that spec. Scared the bejesus out of me when I check fit to early style engine parts.
Looking forward to seeing the entire series, all the way to the finish line.
Old 12-21-2010   #9
Thumbs up Re: Some "Dynomite" Heads!
Great pictures Bob..
Agreed
Old 12-21-2010   #10
No (that is a long story)....by the way..the fire sale heads are very nice
we need to chat about those heads cliff
