01-17-2006 | #1 |
New battery
Looks like I need a new battery. Any suggestions? Thanks
01-17-2006 | #2 |
Re: New battery
How fortuitous that you should be asking just as I was about to poll the forum to see what most of us are using battery wise.
I have an AC Delco in mine which is the same battery it came with when I bought it. It has served me well, but I do put a battery tender on it several times a month. Many people stay with AC Delco since it was the original manufacturer, but the original model is no longer available and has been superceded a few times. Others like the Optima, but you need to cut the top post, and still others like discount batteries like the K-Mart/Wal-Mart/AutoZone specials. So while I will probably stick with AC Delco when the time comes, you may wish to get a few other opinions. Whatever you do, don't get a battery based on price alone, especially a low CCA to save a few bucks. |
01-17-2006 | #3 |
Re: New battery
AC Delco here. It's probably 5 years old now. Battery tender stays on it when not in use.
01-18-2006 | #4 |
Re: New battery
I prefer the Optima, but a few mods will be necessary if its installed in the stock location.
Mike 427 cu in LT5 [URL="http://zr1mk.weebly.com"]http://zr1mk.weebly.com[/URL] |
01-18-2006 | #5 |
Re: New battery
I have heard a lot about these battery tenders, are there different ones on the market and for a person like myself who doesn't drive the car to often and have to store it for the winter months would I leave it on all the time. Is there a prefered brand to buy.
haber rj |
01-18-2006 | #6 |
Re: New battery
No, but you need a charger that will go into a storage charging mode. I got mine the the Corvette Museum.
01-18-2006 | #7 |
Re: New battery
Thank you, my friend just bought a new Turbo Porche and it came with a battrey tender standard equipment, it is just a small compact unit, this could be good or could be bad, he also has a 67 coup, nice car.
haber rj haber rj |
01-18-2006 | #8 | |
Re: New battery
http://batterytender.com/default.php...f69f45503e9ed3 You can put it on and leave it on without worry. |
