11-29-2010 | #1 |
pvc hose's and connector
I need most of the rubber associated with rebuilding the system. I'm on pick a part quest but when I'm finished everything underneath should work as new, any leads would be appreciated. I'm looking at a few parts on ebay, a lot already purchased, and the plenum is off and ready to be put back together better than ever. I've taken a lot of pictures!
[SIGPIC][/SIGPIC] Last edited by lakemeadzmonster; 11-29-2010 at 11:54 PM. Reason: spelling |
11-30-2010 | #2 |
Re: pvc hose's and connector
I also have quite a few USED LT5 parts. Any Jerrys Gaskets PN with the letter U in the suffix denotes a used part. Likewise, N denotes a new part.
11-30-2010 | #3 |
I've got a used vacuum tubing assembly from under my plenum, had no vacuum leaks when removed. No PCV parts, but if you need secondary tubing, I've got it.
