Old 11-26-2010   #1
jrtoffroad
Default HELP! Engine Vibration
Since I purchased my car (91' ZR1) I've noticed a vibration that increases with speed (particularly above 80), but does not always seem present. I thought it might just be the tires flat spotting a little since it often improved with driving.
Today I noticed the vibration, but it seemed more sever than usual. Also, it seemed tied to engine rpm. Now that I have the car home it's idling a little rough and the vibration is very noticeable in the shifter, getting quite bad above 3k rpm (no load, clutch in or out).
I recently installed a set of MSD coils (had a stock one go bad) and while the plenum was off I removed the secondaries. The car has new spark plugs, fuel pressure is good, relatively new plug wires and injectors.
Any ideas??? I don't think the roughness is due to a miss since the power feels good, and most of the related components are new.
THANKS!
Jordan
jrtoffroad is offline   Reply With Quote
Old 11-26-2010   #2
Ccmano
Default Re: HELP! Engine Vibration
Did you change out (modify) the chip to compensate for the removed secondaries?
H
Old 11-26-2010   #3
Kevin
Kevin's Avatar
what do you mean by "removed the secondaries"
Old 11-26-2010   #4
VetteMed
Probably removed the secondary throttle plates, shafts, and actuators, and associated plumbing.
Old 11-26-2010   #5
jrtoffroad
Correct. And yes, the chip was retuned by Mark H.
Just pulled the plugs to see if any looked light or dark. All look perfect. Also tried to look at the harmonic balancer and, from what I cand tell, the rubber looks ok.
Does anyone know how tight the belt tensioner should be? I was able to slacken mine with my bare hand (took a little force, but no 1/2" ratchet required). I found the idler pulley bearing is a little worse for wear, but sadly this is not the source of the vibration, it still exists when running for a sec with the belt removed.
Old 11-27-2010   #6
tomcat
tomcat's Avatar
THANKS!
Jordan
I hope it wasn't 91 #649 that is having the issue
Manfred E........
91 #906
tomcat is offline   Reply With Quote
Old 11-27-2010   #7
jrtoffroad
USAFPILOT had a similar vibration recently. I am not sure if that was resolved.
http://www.zr1.net/forum/showthread....9011&post99011
Thanks. Sent him a PM.
Old 11-27-2010   #8
jrtoffroad
Manfred E........
91 #906
No, my car is 1643 (last 5 of the VIN right?)
Old 11-28-2010   #9
USAFPILOT
USAFPILOT's Avatar
sounds similar to what I have, but mine has not been solved. I hope whatever it is it breaks so I can fix it.
Old 11-28-2010   #10
Manfred E........
91 #906
Whats the story with #649?To the op,the belt tensioner spring is either weak to start with or dies over time.I replaced mine at 8500 on the car.The original was bouncing around quite abit.
