11-23-2010 | #1 |
Changing Inst.lamps in 90 ZR1
Hi,
Been through my FSM and I can't find any instructions on changing burnt out instrument panel lamps. Is it necessary to remove the whole IP to change out the lamps ?. Thanks Don |
11-23-2010 | #2 |
Re: Changing Inst.lamps in 90 ZR1
I believe the answer is yes..
as they lock in from the back if I recall right
11-24-2010 | #3 |
Correct. You need to drop the steering wheel as well in order to get to the IP surround or risk breaking it. Once that surround is out of the way the job is pretty easy.
11-24-2010 | #4 |
Oh Well, things happen like that sometimes. Thanks everyone for the good news.
Happy Thanksgiving and Merry Christmas Don and Cherry in VT |
11-24-2010 | #5 | |
Manfred E........... 91 #906 http://pnwzr1.net |
11-24-2010 | #6 | |
Yep they will heat uneveningly and burn out sooner if your fingerprints and oils get all over them.
