![]() Join Date: Feb 2009
Gathering my tools for replacing my rear axle hub bearings. Anyone have a source for a 3/8 drive LONG T55 Torx? Everyone has long shanks up to T50 but not T55.
Rich
![]() Join Date: Aug 2006
Check w/ Phil. Since we were able to pull mine he must have had one.
Come to thisnk of it, may be we used an extension... |
Got both long and short in T55 you are welcome to borrow
Phil |
![]() Join Date: May 2007
I think I used a regular T55 with 3/8 drive extensions to suit.
How about scheduling a MD so some of us can come help/supervise? Jim |
#6 | |
![]() Rich
I will come help put headers on your car. (If it is scheduled on a day I am not working.)
Are you planning on replacing the suspension bushings when you replace the hub bearings? Jim |
Good idia Jim
Should be a snap if bring along the WAZZO 12 ton duty bench press |
#9 | |
![]() Yeah, that's the plan. I was talking to Yun the other day since he has been down this road already. Rich
#10 |
My suggestion is do bearings, u-joints and all rear bushings simultaneously. If we have 2 teams should be able to knock it out in 8 hours or so.
