11-14-2010 | #1 |
My own fire sale list
Secondary Vacuum pump, nearly new, $80
McLeod Aluminum Flywheel, new, $250 ACDelco spark plug wire set SOLD 90-93 sport seat lumbar inflation pump SOLD Red rear Corvette emblem 91-95 SOLD Aqua rear Corvette emblem 91-95 $45 previously mounted but very nice Black with silver rear ZR-1 emblem $40 new unmounted White LT5 emblems SOLD CNC'd black aluminum faceplate for mounting single DIN radio in dash, has CORVETTE machined into face $40 LT5 starter, needs rebuild, $50 Saddle tire strap for cargo area $75 Spare ECM, unknown if functional SOLD FX3 controller 90-91? SOLD Fuel door assembly, white, fair condition, emblem faded SOLD Front a-arms SOLD Rear camber rods $10 each LEFT SIDE PENDING Rear trailing arms $5 each ZR-1 License plate surround / frame SOLD Chrome oil filter cover SOLD used fuel pump assembly, no pumps, working sender SOLD 91 ex manifolds, bad cats, crack in pass side cat housing, $50 each Baer eradispeed rear rotors, one is cracked, other is OK, $40 for good one, cracked is free with purchase SOLD Rear calipers $40 Rear abutment brackets $40 post wants in this thread. All prices plus shipping. Last edited by VetteMed; 11-22-2010 at 07:45 PM. Reason: price drops, new items added. |
11-14-2010 | #2 |
Re: My own fire sale list
Got a photo of rear eradispeed rotors?
Might be interested in both. Are they drilled slotted 2 piece? |
11-14-2010 | #3 |
I can get pics tomorrow. They are drilled and slotted 2-piece, the center hats are in good shape on both.
11-15-2010 | #4 |
Pass. side rear camber rod. Is the trailing arm
the rear lower control arm? |
11-16-2010 | #5 |
11-16-2010 | #6 | |
Control arm is NOT the dog bone but the arm extending from diff to lower hub carrier assembly. Correct? If so, we can make arrangements for that and the tie rod. |
11-16-2010 | #7 |
I would be interested in the White LT5 emblems. Can you send a photo?
How many do you have? |
11-16-2010 | #8 |
I also want:
Fuel door assembly, white, fair condition, emblem faded, $10 Front a-arms $20 each Chrome oil filter cover $15 used fuel pump assembly, no pumps, working sender $50 And the White emblems! Thanks! Kevin |
11-16-2010 | #9 |
Hi,
Can you give me any info on the starter. Year, miles, general condition. I guess any info would help. I am interested. Regards, Don in VT |
11-16-2010 | #10 | |
The camber rod, which extends from the bottom of the diff, to the bottom of the knuckle, I do have, for both sides. |
