Here is the first list. Prices are cheap (for LT5 stuff )
![]() Interior parts: 94 A/C controller-$25 -Kurt 94 A/C black box with vac hoses-$25-Kurt Rear compartment door assemble-$15-Phil Jag Rear tray compartment-$10-Phil Jag Black ZR-1 floor mats front and rear-$45-VettMed Black ZR-1 sill covers-$15- David Seat back plastic bezel in GM bag-$25 94-95 Center Dash Bezel ? in GM bag- $175-Phil Jag Shift/Ash tray bezel- $25-Phil Jag Instrument bezel-$15-Phil Jag 94 Red driver side door panel-$75-Ricky 94 Red under dash driver hush panel-$25-Ricky 94 Red under dash passenger hush panel-$25-Ricky 94-95 head light/fog/abs switch assembly- $100 Body Parts: 91-94 both gills- $100-gen2rt -jack 95 passenger side gill-$50-Ricky Rocker panels both-$150-Xfire New emblems gas/hood-$25-Phil Jag Original metal emblem gas/hood-$15- Ben PAID & SHIPPED ZR-1 emblems 6 AB, 3 Polo - $40 ea- David 2AB Corvette emblem 1 AB, 1 Polo-$50 ea- David 1AB Outside door handles both-$25-Phil Jag Bronze top-$150-David Third brake light lens-$10 ZR-1 windshield late 93 date code-$500- zrss Jim and 402 right buddy :-) Suspension Parts: Coil over DRM kit 425/275 with FX-3 shocks(500-or 1500 miles) $1000 -David DRM relocate brackets new -$150-David ?? 1 90-92 rear shock-sold Rear knuckles -$25 Rear brake caliper holders-$25 Motor Parts: 91 block LA sleeves fresh bore/hone 4.010 ready to build-$1500 Oil pump-$150- Dynomite Pan assembly pickup/tray-$250 Front cover-$100-Dynomite Alternator AC/Delco new-$125-Russell Alternator used-$65 Breather box and baffle-$125 A/C compressor with clutch 91-95 - $250 Power steering pump 91-95 - $75 Stock cams 91-$200 ea Heads no cams 91-$ 500 ea- Dynomite both L&R Plenum 91-$300-Locco Injector housings 91- $125ea-Locco Throttle body 91-95-$300-Dynomite Air horns 2-$75 ea-1 Dynomite 1 Locco 350 cranks 2 -$75 ea 1-johnny phrogs 350 piston/liner/rods under 10k miles-$600- jeff f Balancers new/used- $100-$65 (used match to crank johnny phrogs) 1 jeff Chain guides all with strips-$100ea Chain guide wear strips all-$75-jeff Main bearings new coated-$650 Reconditioned GM?s coated- $450 Pulleys Randy Woods-$50-Phil Jag Oil cooler line kit-$75-Xfire Secondary parts new/blades/actuators/levelers/everything from heads-$150-Dynomite 90-92 exhaust manifolds stock cats -$175 91-92Heat shields-$25-Ricky Plug wires LT-5 NEW in the box-$300-Dynomite Plug wires new Delco-$50 Smog pump /tubes/lines 92 -$50 Bell housing with fork-$75- Phil Jag Misc parts: Spare tire-$25-johnny phrogs Spare tire holder and brackets-$25-johnny Spare tire bag -$50- 91 vettezr1 Todd License plate holder rear-sold Jack and bag-$15 SS brake lines front-$25-Dynomite Fuel lines from motor to frame with filter-$25-VetteMed Stock filter lid metal-$5 3:73 gears new in box Viper with Speedo gear -$ 150-Phil Jag Samco intake boot in bag-$100 - Phil Jag Speedware Motorsports Harness bar with camera mount- $250 Best bar out there.-Phil Jag 94 used Master brake cylinder-$25 91 used Clutch master and slave with line-$50-johnny phrogs Corsa?s-$500-Aaron ammrpm Fuel pump assembly stock used -$75- Russell Pizza box 90-$100-ZeeAreOne Pizza box 91-$100-Limey Rear ABS sensors-$25 ea Last edited by Polo-1; 11-20-2010 at 05:09 PM. |
Kevin
I'm interested in (will take): Rear compartment door assemble-$15 Rear tray compartment-$10 94-95 Center Dash Bezel ? in GM bag- $175 Shift/Ash tray bezel- $25 Instrument bezel-$15 New emblems gas/hood-$25 Outside door handles both-$25 Pulleys Randy Woods-$50 Bell housing with fork-$75 3:73 gears new in box Viper with Speedo gear -$ 150 Samco intake boot in bag-$100 Speedware Motorsports Harness bar with camera mount- $250 Best bar out there. Please PM the total with shipping. Thanks, Phil Last edited by Jagdpanzer; 11-14-2010 at 02:02 PM. Reason: Added "(will take)" clarification |
New hood/gas emblems if jagd passes clutch master & slave with line - is this used or new? miles? same for brake master cyl? stock filter lid fuel lines from frame to motor Oil cooler line kit - is this oem, nos, aftermarket, used? What color are the floormats? _________ Updated 2:22PM, only interested in floormats and fuel lines. All other items I will pass. Last edited by VetteMed; 11-14-2010 at 02:23 PM. |
Alright guys....
I'm getting phone calls and pm's.... Lets try to keep it out here, for my sanity.. Please no paypals yet.... If you lay claim to it here I'll hold it for you. |
anything "91" part is from running motor with 50k on it.
The clutch Mater and slave/line is still all together uncorked from the running 91. Same with T.body. all sensors and lines are still on it. |
Yes.
I have not looked at all the gaskets and other stuff... |
![]() Join Date: Apr 2004
Polo, I'll take the floor mats for $45 plus shipping.
damn this is what i get for sleeping in...I was looking for a rear plate frame
#9 |
lets keep it out here.... Email from David @10:43 am
94-95 Center Dash Bezel ? in GM bag- $175 Black ZR-1 sill covers-$15 Bronze top-$150 (depending on shipping) ZR-1 emblems 2 AB, Corvette emblem 1 AB, -$50 ea Ricky will want these below Red driver side door panel-$75 Red under dash driver hush panel-$25 Red under dash passenger hush panel-$25 Last edited by Polo-1; 11-14-2010 at 01:54 PM. |
#10 |
![]() Join Date: Dec 2005
I will take the red hush panels both sides & door panel, if they are for 94-96. Thanks
