Okay, for the past month or so I have been having an intermittent problem with the Z stumbling while cruising. I first noticed it while driving at constant highway speed on a trip from Dallas to Houston. It would stumble or "hiccup" for a few seconds at a time as if it wasn't getting enough fuel. It did this for about 1/2 an hour and went away. I pulled the plenum and changed the alternator, coils and wires. I checked all the vacuum hoses and added zip ties to the connections. The hiccups would pop up very rarely after that.
On Vets day I got caught in a downpour and the stumbling came back, but this time it had a hard time accelerating from a stop. It struggled to accelerate until I stabbed the gas pedal, then it would accelerate normally. I pulled over and it shut off. It did start back up immediately after and seemed to work fine after. Yesterday, it was driving fine until I got a block from home, the stumble came back coming trying to accelerate from a stop and the idle went to 1200 rpm and kept rising to 2000 rpm. Here is some background on the car. It is a 94 with 36k miles on it. It sat for several years before I purchased it earlier this year. I bought it with 33,5k miles and the PO only put 2k miles on it in the preceding 2 years. The fuel filter and plugs were all changed earlier this year. Any ideas? |
you might ck the sensor that on the rear of the manifold (map sensor )to see if the vacume connection is either full of oil or if it has just a rubber hose that connects it if the hose has gotten soft and is collapsing .also there is a map sensor right under the computor in the engine compartment thats partof the the secondary system . are you getting a ck engine light . do you have a scann tool to ck for codes . other things that could be causing it are your tps ,might have developed a flat spot . or the iac may have started to go south . does your secondary vac pump go on and stay shut off when you turn the key to on (but dont start it ) or does it cycle on every couple of seconds ????if it does you still have a vac leak.
How does it idle? Any surge?
Idles smoothly, the MAP hose is new and clamped secure. The vac pump cycles every 5 seconds with key on engine off.
#6 | |
![]() Join Date: Nov 2007
Do you have a scanner? I swear...The ZR-1 should come with one as standard equipment: not that they're trouble prone, but these cars are rare and not many shops have even seen a ZR-1. I got a scanner on a close-out sale, but I'd pay twice as much if I had to if I had to replace it! That said, I'm gonna take a WAG and zero in on the TPS too, as I have a little spot on mine that I never notice if I sweep past it quickly. But, dawdle on the throttle opening, and I get a quick little stumble. It's on my radar, but not a priority item...yet. P. |
I don't think the vacuum leak is the source of the stumbling either. The secondaries are working fine. I did clean the IAC as it was kind of "sooty" and the idle went back to normal.
I need to get a scanner any recommendations on which one to get and where to get one? Also, what's the best way to check the TPS? Thanks |
#8 | |
TPS reading is easily done with scan tool. Bit more difficult using DVM |
#9 | |
There is a leak, but from what I've read it's just a minor one and wouldn't cause my problems, but I will take your advice and narrow down the leak just in case. Last edited by pantera1683; 11-15-2010 at 11:51 AM. |
#10 |
