Old 10-31-2010   #1
QB93Z
QB93Z's Avatar
Default Cause of Blowing A/C Clutch Fuse Corrected
My 1993 ZR-1 had an A/C problem. The A/C Clutch 10 amp fuse was blown and since it provides power to the A/C Control module, all control and indications are lost.
My plan was to replace the A/C compressor and clutch.
However, after pulling the plenum, I discovered that the problem was a pinched wire to the compressor clutch:
Apparently the wire had been pinched between the plenum and injector housing. After the insulation wore through, the wire was shorting to ground, blowing the fuse.
Easy to fix by removing the lead from the connector and sliding a short piece of shrink tubing over the wire.
Everything OK now.
Old 11-01-2010   #2
Aurora40
Aurora40's Avatar
Default Re: Cause of Blowing A/C Clutch Fuse Corrected
Nice find, and much easier than opening up the A/C lines!
Old 11-01-2010   #3
secondchance
Saved one compressor!? That's great. Sorry I missed out on this get together.
Old 11-01-2010   #4
QB93Z
QB93Z's Avatar
The good news is: I didn't have to disconnect any freon lines.
The bad news is: I had the shop suck out all the freon before the job.
Old 11-01-2010   #5
QB93Z
QB93Z's Avatar
Scott stopped by (with his Z06). We talked about C4 rear suspension dynamics. We missed you.
Old 11-01-2010   #6
Aurora40
Aurora40's Avatar
Ahh, that sucks. I wondered how you were planning on handling that. Apparently, the legal way.
Old 11-01-2010   #7
Scrrem
Scrrem's Avatar
Great find Jim, too bad you had the freon sucked out.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 11-02-2010   #8
Great find thanks for the post up
Old 11-03-2010   #9
Any difference in performance? Could have caused vacuum or coolant leak if it kept the gasket from sealing.
A26B is online now   Reply With Quote
Old 11-03-2010   #10
It appear's the green AC line was pinched between the compressor and plenum.
