Old 10-27-2010   #1
Belsy
Belsy's Avatar
Default low tire sensors
HELP!! Tire genius knocked my blue sensor loose while breaking down for new tires. I have some ???
1. Do the sensors have to be where factory placed by color? i.e. blue L/F etc.
2. Sensor was clamped back on wheel but I am not sure wheel was set for left frt.( he may have set left tire on right wheel for rotation)
3. Light came on after several miles and I am still testing
4. Are they being remade or substituted by anyone?
Any help appreciated,
Belsy is offline   Reply With Quote
Old 10-27-2010   #2
xlr8nflorida
xlr8nflorida's Avatar
Default Re: low tire sensors
Yes
eBay or check around lots of people have spares check with member phrogs
Old 10-27-2010   #3
VetteMed
Each color is specific to the proper corner of the car - there's no learning procedure or other way to change that. If the tire jockey put it on the wrong corner, then it will be read by the LTPWS module as the wrong corner, as it has no way of knowing where that sensor is actually mounted.
No aftermarket substitutes, but there's always spares coming up for sale sine most folks ditch the system.
Old 10-27-2010   #4
sammy
i have 11 spares for the 90 cars let me know if your in need .
Old 10-28-2010   #5
USAFPILOT
USAFPILOT's Avatar
They swapped corners on me and it works just fine. I was sorta pissed at the guy for not just swapping the tires again, but he said it would work anyway, so I let him put them on the car and no light. The car is a 94 so maybe at some point they became capable of figuring it out anyway?
Old 10-28-2010   #6
Kevin
Kevin's Avatar
just take all of them off. makes everything better
Old 10-28-2010   #7
VetteMed
No, it's just that if your LF tire is low, but it's actually the RF wheel that is mounted on the LF, the LTPWS will report the RF as being low. The system will not trigger a service light if it is receiving from all 4 sensors, regardless of where they are mounted.
