Old 10-23-2010   #1
Mr Cool
Default Secondary port vacuum solenoid
Picked up a 90 last month had it running great for two weeks after replacing the injectors. Now with key on engine off my pump was cycling so I pulled the plenum back off. Looks like the vacuum solenoid is leaking bad anybody know where I can get a replacement?
Mr Cool is offline   Reply With Quote
Old 10-24-2010   #2
Default Re: Secondary port vacuum solenoid
Congrats on the ZR-1 score.
Info >>http://www.corvetteactioncenter.com/...0/002/article/
the part is >> Vacuum Solenoid with conical air filter (Part #1997222)
We will see what others say for where for you to get one at.
Welcome to the Brotherhood and the Zoo.
Use the solutions thread for problem investigations and suppliers
>> http://www.zr1.net/forum/showthread.php?t=11619
Old 10-24-2010   #3
I think that you can still buy one at the chevy store, no? If not either hit up either of these links:
http://jerrysgaskets.com/store2/root/
or:
http://whiteracingproducts.com/
Those guys will be able to fix you right up.
Old 10-24-2010   #4
Belsy
Belsy's Avatar
I went thru the same problem, Delco # 214358 works after minor bracket change ($20) also cross GM# 1997212 if nec? Make sure check valve is good (I missed & had to pull again) if nec a small check valve at plenum (drivers side) will work. The fuse for pump should be #17 / valet on dash pass. side.
Let us know how you do.
Belsy is offline   Reply With Quote
Old 10-24-2010   #5
Mr Cool
I looked at Jerry's website yesterday, didn't see any. White racing has one in a kit $620 ouch. Might need to call them and see if I can just buy the valve.
Old 10-24-2010   #6
Mr Cool
Could you double check that Delco # I could not pull it up on GM Parts direct.
Thanks for the help
Never mind, found it thanks.
Old 10-24-2010   #7
Belsy
Belsy's Avatar
Holding the box in my hand, ACD# 214-358 with GM# 1997212 shown on the lid. Call me if you like to discuss the process I followed 407-391-9492.
Old 10-24-2010   #8
Mr Cool
I found it. Thank you
Old 10-25-2010   #9
Hey Gene if you post details of the conversion here on this thread member Dynomite will pick it up and add it to his solutions index for others in the future to use.
Solutions >> http://zr1.net/forum/showthread.php?t=11619
Would be great for members in the future to be able to do this and $ave.
Old 11-02-2010   #10
Mr Cool
Finally got back to working on the car today. I got the solenoid Belsy suggested, and swaped mounting brackets with the original. Now all is good again. Thanks. Guess I'll let my wife (it's her car) drive it for awhile before addressing the next problem.
