Old 10-20-2010   #1
pantera1683
Default heavy duty alternator
My alternator is about to take a dump on me and I would like to replace it with one with higher capacity, any recommendations?
pantera1683 is offline   Reply With Quote
Old 10-20-2010   #2
pantera1683
Default Re: heavy duty alternator
I found a 200 amp reman on ebay, I think I will go with that one.
Old 10-22-2010   #3
gbrtng
gbrtng's Avatar
Approach with caution - If that thing goes full current due to a failure, you will probably end up with some toasted wiring. The heavy red wire from the alternator is sized for the output of the stock system which is 130 amps (I think). Why do you need more capacity?
Old 10-22-2010   #4
pantera1683
I'm going with the 200 amp alternaotor because I added some electrical accessories that are taxing my stock one. With all my accessories and lights on I only get about 11.5 volts. I had the system tested at autozone and the result was low output under load.
