![]() Join Date: Jul 2004
Hi everyone
I want to flush the brake fluid and I'm confused by the two reservoirs (car is a '91). Do they bleed seperately or does it act as one big reservoir feeding the MC? I looked in the FSM but it doesn't seem to mention which you bleed (or both). Does one cylinder service the front brakes and one the rear? Any advice/info gratefully received. Thanks Dave
1991 #1516 Black/Black davidmkelly.com Author of fast-paced, sci-fi thrillers. |
![]() Join Date: Feb 2006
The front reservoir is for the front brakes and the rear for the rear brakes.
Suck as much old fluid as you can with a turkey baster or similar gadget. Fill both with clean fluid, lightly cap both, and start with RR, then LR making sure the reservoir never runs dry. Flush until you see clean fluid at both calipers - usually 10 to 15 pedal applications. Then move to the front and flush RF and then LF.
Thanks for the info. In the FSM it says the bleed order should be RF, RR, LR, LF - is there a reason not to do it that way?
Go ahead and use the FSM sequence - I just told you the sequence I've always used.
Personal preference ...
![]() Join Date: Nov 2006
Thanks. The front/rear aspect makes that sequence seem more sense
![]() If using a pressure bleeder, I assume you'd pressure bleed both reservoirs? Only reason I mention this is that the pressure bleeder I have doesn't look as if it would fit on the rear due to interference with the power steering. I have a turkey baster ![]() Thanks Dave
#7 | |
It's a lot easier to enlist Wifey's assistance to mash the brake pedal. Turkey baster, a hunk of tygon tubing and a pan is all the caveman equipment I use.
#9 |
I think you are supposed to do the RF RR LR LF in order to not mess up the ABS.
#10 |
Thanks everyone
