Old 09-20-2010   #1
DaveK
Default Rattling noise on shutdown
Over the last week or so I have noticed I sometimes have a kind of 'rattling' noise when I switch off the ignition. It's not always there and definitely is after the engine has stopped. Sounds a bit like a piece of wood rattling around somewhere.
I've done a visual inspection and see nothing obvious. The sound seems to come from the very front of the engine bay so I am thinking it's probably a cooling fan bearing or similar on the way out? If that's the case how am I fixed for a replacement fan?
Anyone have any other ideas of what it might be?
Thanks
1991 #1516 Black/Black
davidmkelly.com
Author of fast-paced, sci-fi thrillers.
Old 09-20-2010   #2
Scrrem
Scrrem's Avatar
Default Re: Rattling noise on shutdown
Thanks
It could be your dual mass fly wheel dampers going bad. How many miles on the car?
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 09-20-2010   #3
DaveK
Thanks Rich. 100,000 km/60,000 miles.
Wouldn't the flywheel damper sound more as if it were inside the cockpit or close to the bulkhead?
davidmkelly.com
Old 09-20-2010   #4
Scrrem
Scrrem's Avatar
Sorry Dave, I should have read you post more carefully I suppose it could be the cooling fan bearing. Have you checked your idler pulley? I had a strange knocking sound that my 90 made with the enging running. It ended up being a water pump bearing. I never heard a water pump bearing knock like this one did.
Rich
Ron Davis Radiator
Old 09-20-2010   #5
DaveK
I'll check it but this is happening after the engine has stopped so I don't think the idler or water pump would be still turning.
Thanks!
davidmkelly.com
Old 09-20-2010   #6
Ccmano
Dual-mass flywheel... mine does it too. If you ever watch closely at the moment when an engine comes to a stop, the piston compression causes it to come to an abrupt stop or even a slight backwards rotation. This causes the flywheel to occilate a few times if the damper mechanism is shot. BTW mine has 61K miles on it. Seems to work fine otherwise. I'm just waiting for more of a reason before I go to all the work of dropping the trans to replace the flywheel and clutch. I have a low mile D/M flywheel sitting on my work bench waiting to that day.
H
