Old 09-20-2010   #1
shaynezrl
shaynezrl's Avatar
Default clutch master part ?
Anyone know where i can buy an original clutch master cylinder that came with our car? I've install an aftermarket part but its not the same as the old one that came with the car. The rod on the new one are shorter.
Shayne
shaynezrl is offline   Reply With Quote
Old 09-21-2010   #2
Default Re: clutch master part ?
Shayne
Is this the G.M. part?
Old 09-21-2010   #3
shaynezrl
shaynezrl's Avatar
Jeff,
I bought it from Chevy Dealer in Antioch. The box label AC Delco. I called them to tell them difference, their reply was it is an aftermarket part with ac delco name on it. When i compare the old one side by side the rod on the original is much longer. I'm lost as to finding the same one NEW. On the original part, the clutch pedal would travel to the floor the one does not.
Old 09-21-2010   #4
xlr8nflorida
xlr8nflorida's Avatar
Jeff,
Where you located? Can you post pic up, I might have solution for you.
Old 09-21-2010   #5
shaynezrl
shaynezrl's Avatar
I still have the box from gm. I will get a pic tm and post it. As for the old part i already threw it away. I am located in Antioch ca.
Old 09-21-2010   #6
i bought the master cylinder a few months ago and wont get a chance to install it anytime soon,I need to return it if its the wrong part.How long is the rod,the one I have is 3 inches long.
Old 09-21-2010   #7
shaynezrl
shaynezrl's Avatar
Here is the picture of the box. Jeff i don't remember the exact length difference, but it is significant.
Old 09-21-2010   #8
Give Bill a call ,
http://zfdoc.com/index.htm He'll do you right.
Old 09-21-2010   #9
ZR1FUN
I ran into what I thought was this same probem a couple of months ago when I changed out my clutch slave cylinder. It turned out the orginal shaft had not fully re-extended due to the crude in the cyclinder. When I pulled both shafts out they were exactly the same length. Maybe this is what you are seeing also although I was working on the slave and not the master. There was no problem with the new master.
Doug
ZR1FUN
ZR1FUN is offline   Reply With Quote
