Old 09-11-2010   #1
batchman
Default name that catback
Can anyone identify this catback? Besides some drone it seems pretty good, but I am running close to the sound limits at some events. Wonder if these mufflers degrade, I haven't changed anything. Are these mufflers heavy?
(haven't had it off - yet)
Thanks,
- Jeff
Old 09-11-2010   #2
1990 415
Default Re: name that catback
Borla. Quite restrivtive. I got rid of mine long ago.
1990 415 is offline   Reply With Quote
Old 09-11-2010   #3
VetteMed
The square tips are the giveaway, definitely Borla.
Old 09-11-2010   #4
xlr8nflorida
xlr8nflorida's Avatar
It's Borla, I have it on my Z. You may lose 5-10hp on this exhaust setup, but it has zero or minimal resonance.
With a set of Headers, No Cats, modified resonator the system works great. It's quiet but comes to life when you get on it.
If you are looking for something loud, go with another exhaust like B&B.
Old 09-12-2010   #5
so what is modified on your resonator?
Old 09-12-2010   #6
100% agree its a Borla. Suggest Corsa
Old 09-12-2010   #7
Prob LT4 resonator would be my guess
Old 09-12-2010   #8
xlr8nflorida
Borla necks down as it enters the resonator. You need to make resonator so it doesn't neck down.
You modify existing resonator or you buy LT-4 resonator.
Old 09-12-2010   #9
I see.. I have the Borla Challenge system.. I have a LT4 resonator and I also have a Magnaflow resonator.. debating on which to try first
Old 09-12-2010   #10
Aurora40
Aurora40's Avatar
They can degrade. Borla uses a packing material as the means of sound attenuation. I don't know the specifics, if it's all glass packing, or glass and steel.
The packing can get compressed to where it does not work as well, or get shifted around or blown out of the casing over time. So yes, they can degrade. If you've had them a long time and they seem louder now than they did, it's possible that's what happened.
Heavy, I don't know. I don't think the weight range is enough to choose a muffler based on it vs sound quality.
