Old 08-14-2010   #1
jrd1990zr1
jrd1990zr1's Avatar
Default PCV tubes inj housing to PCV valve tubes
I am looking for both the right and left side PCV metal (aluminum) tubes from the injector housing to the PCV tube the valves mount in. Must have the metal hold down to the injector housing bolt. I need these for a 1990 MY.
Previous owner broke the tabs off so I am thinking of replacing them for judging purposes. I don't want to pay huge $. Hope someone has a pair for a reasonable amount.
Thanks, John
Old 08-14-2010   #2
Aurora40
Aurora40's Avatar
Default Re: PCV tubes inj housing to PCV valve tubes
Have you checked to see if they are still available from GM?
Bob Saveland
Former owner of #2517
Old 08-14-2010   #3
John,
If the tabs are still under the inj hsng bolts, just have them rewelded (tig) to the tubes by someone who knows how to to do pretty work on light aluminum.
I also have the RH side on the website, new & used.
RH-used
http://jerrysgaskets.com/store2/root...roducts_id=300
RH-new
http://jerrysgaskets.com/store2/root...roducts_id=172
Old 08-14-2010   #4
Jagdpanzer
Jagdpanzer's Avatar
I saw a set of these tubes listed on ebay the other day.
Old 08-14-2010   #5
phrogs
phrogs's Avatar
I have only seen a couple of these in all my dealings with ZR-1s that were not broken.
It seems they just break from vibration or something like that just a weak weld.
Id have someone weld them.
JOHNNY P
Currently own
Old 08-15-2010   #6
jrd1990zr1
jrd1990zr1's Avatar
Me too.
Some one out bid at the last second.
Thanks for the reply. Going to look around Carlisle.
Old 08-15-2010   #7
jrd1990zr1
jrd1990zr1's Avatar
Thanks, I'll have to check. I figured something like this would be long discontinued.
Old 08-15-2010   #8
jrd1990zr1
jrd1990zr1's Avatar
John,
RH-used
RH-new
Thanks Jerry,
Unfortunately the previous owner must have lost the pieces. They were not on the plenum when I changed injectors.
I am going to look around Carlisle for a pair, If I don't find a pair I will be visiting your website.
Thanks, John
Old 08-15-2010   #9
Aurora40
Aurora40's Avatar
I thought I'd seen them available and reasonably priced in the past. But maybe it was from somewhere like lt5-parts.com (which is now Jerry's) and not from GM? It's easy enough to check though.
Bob Saveland
