Been looking around now for some info on a supercharger kit for a 1991 ZR1. Found infomation on the 1992-96 ZR1 models but not for my 91. Do they have such a kit? Would the one for 92-96 fit? Would one made for a ls1 work? Can anyone steer me in the right direction? Thanx
Understand SRP is working on a ZR-1 super charger system package:
http://www.zr1products.com/ |
#3 | |
#4 | |
1- what about the already-high compression of the LT5 when it is pushed beyond its original limits? 2- why do they call underhood air intakes "cold air"? There is nothing "cold" about air sucked in from underhood temps guaranteed to be at least 100 degrees hotter than from outside the engine compartment. Just wonderin'. ***Looking closer at the pics I can see the "cold air" filtered intake is moved directly above the battery. I also see the left side plenum water pipe has a tube routed from the back to "somewhere". I cannot see the power steering pump and reservoir in the pics. Lots of new "controls". No info about added compression. Last edited by dallas; 08-13-2010 at 10:33 AM. |
Has anybody in the FBI gone out to this shop to see this setup yet?
![]() ![]() Join Date: Aug 2005
Randy (& Dad) had the SRC SC LT5 at the last BG Gathering.
VERY CLEAN looking but A LOT of work. Randy said he is still working out the bugs and fine tuning the program. And I know you didn't ask, but Ron H. (Raptor) is marketing a remote turbo system for C4's and LT5's. Last edited by tf95ZR1; 08-13-2010 at 12:55 PM. Reason: Wanted 2 |
#7 | |
![]() Join Date: Dec 2003
Car was at BG this year. I've seen this set up,it's a clean install just like any other SC system installed in L98,LT1 etc. The only question i have if i were to put one in my Z with the cams and run 4lbs of boost will i get 75HP? Then i would be 441 power. ![]() Pete
#9 |
Wonder what the price point will be as opposed to the TT setup. Dyno numbers would be good too.
#10 |
![]() ![]() Join Date: Dec 2003
When I talked to Randy in BG this year, I asked about pricing. His comment to me is that he won't be selling this setup. This is a one of one for him.
Dennis Fierstein 90 ZR-1 #2562 Atomic-Z ZR-1 Net Registry Chairman of the Board ZR-1 Net Registry Treasurer |
Tags |
1991 zr1 supercharger |
