Old 08-09-2010   #1
902066
Default Lowering Bolts
Put in longer bolts to bring my rear down a little. Got it where I want it, [27 1/2" from ground to lip of rear wheelwell]. On passenger side I have a 1/4" of bolt left after locking nut, drivers side I have 1 3/4". Is it normal for their to be that much difference side to side?
902066 is offline   Reply With Quote
Old 08-09-2010   #2
Default Re: Lowering Bolts
Rear spring droop. Pretty normal
Old 08-09-2010   #3
carter200
carter200's Avatar
You can't trust body panels for level area. There are factory measuring points but they escape me right now Good luck
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 08-09-2010   #4
Kb7tif
Lowing the rear using the bolts can "soften" and add bouncey-ness
Since your already uneven, hell of a time to replace that spring with the one in my other post, Im pretty sure thats the most stout spring ever for a vette, and i buy it in a flash if I still had a corvette. BMH Rate
Kb7tif is offline   Reply With Quote
