Old 08-06-2010   #1
xlr8nflorida
xlr8nflorida's Avatar
Default Clutch master/slave cylinder nos
Are these still available? How much?
Don't care for rock auto ones.
Old 08-06-2010   #2
richard sanderson
Default Re: Clutch master/slave cylinder nos
Why not? I am getting their Wagner cylinders, and the reports I have seen are very positive! Cheers Dick
richard sanderson is offline   Reply With Quote
Old 08-06-2010   #3
xlr8nflorida
I don't like the cast look or blatantly obvious non stock parts.
Can you keep body and change out internals in the form of a rebuild?
Old 08-06-2010   #4
vettn71
I'd like to know. also. I had to go to a cast version, but still have the OEM used-up ones.
vettn71 is offline   Reply With Quote
Old 08-08-2010   #5
That's what I did awhile back when GM was having Q/C issues. I used a cast slave as a donar for the internals and stuffed them into a DOM body.
I guess you could do it to the master. I don't see why not. I never did because my car isn't a NCRS type car so I never tried. You can't see the master so I just didn't bother, the cast slaves don't fit well on the stock studs, the studs are too short to get many threads caught on the nuts. That was the only reason I did the internals swap. I did that at least three yrs & 20k miles ago and it's still working fine.
