![]() Join Date: Nov 2007
The knock sensor is a piezoelectric crystal with a pickup wire. But, apparently, the associated "plumbing" includes a resistor network that differs among the model years. According to Bob G, a sensor from another MY resulted in considerable timing retarding on one of his engines (the ECM falsely sensing knock, apparently).
Mine works, far as I know, but the plastic ring to which the connector "grabs hold" got brittle with age/heat and part of the ring broke off - now making the connection precarious at best! So, Q: Has anyone found a reasonable facsimile, if not an OEM, knock sensor that works on a 90? Granted, the connector may have to be changed to accommodate one from a different source/application, but this car is an FBI "warrior" and not a waxer; NCRS is not an issue here. ![]() TIA P. |
![]() Join Date: Dec 2003
I didn't know there was a difference in the knock sensors until I went to the ACDelco site: Lo & behold, the 90 is a different PN.
1990 SENSOR,KNOCK Part Number: 213-94 Product Notes: [Knock Sensor] Per Vehicle: 1; Years: 1990-1990 CONNECTOR,SEN-KNOCK Part Number: PT2295 Product Notes: [All Makes-Sensor-Knock Connector]; 1-Way male Per Vehicle: 1; Years: 1990-1995 ------------------------------------------------------ 1991~95 SENSOR ASM-KNOCK Part Number: 213-266 Product Notes: [Knock Sensor(VPI 1-877-846-8243)] Per Vehicle: 1; Years: 1991-1995 Vehicle List CONNECTOR,SEN-KNOCK Part Number: PT2295 Product Notes: [All Makes-Sensor-Knock Connector]; 1-Way male Per Vehicle: 1; Years: 1990-1995
