Hi All,
It looks like the stock switch is not available new. I am sure that one will show up used but will probably fail soon. One member responded with a link to a source for a new switch but it seems too long for the application. I will check into that switch however. Some of us that live in states where vehicles have to pass a basic inspection where all the lights have to work or you can't get your registration and or plates to drive in the state. I read the law and the lights have to work when the transmission is put into reverse. If all else fails I will design a switch that works with the shift linkage. Based on what I have been reading, there are a lot of owners that are in same boat that we are. Perhaps one of the suppliers out there could pick up on this opportunity, To help me understand this switch: Does it only control the backup lamps ? If not, what other functions does it interact with ? What operates the switch ? A push pin from inside the tranny ? Oil pressure (not likely) I know that someone in the forum has designed a clever relay circuit that is effective but even that requires a working switch. It might be helpful to take a poll on how many folks out there need switch. I would do the poll but I am new to the forum and I just don't know how to do it. Got to start somewhere Regards Don ![]() |
![]() Join Date: Feb 2006
