Old 07-22-2010   #1
Pete
Pete's Avatar
Default WTB: SGC Stage I Exhaust Cams
Anybody have a set of SGC Stage I exhaust cams,they wanna sell.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 07-23-2010   #2
Pete
Pete's Avatar
Default Re: WTB: SGC Stage I Exhaust Cams
Found some.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 07-23-2010   #3
Pete,
With ported heads would you recommend Stage 1 intakes and stock exhaust? Or Stage 1 all around? Ideas as to $ for either.
Old 07-23-2010   #4
Pete
Pete's Avatar
Pete,
Yes,stock exhaust cams with Stage I intakes will not gain you much.
For low cost i would do Stage II intakes with stock exhaust,if money no object i would do Stage II with a .220 exhaust.
Man i can wright a book on this stuff, so since you asked,
Remember we have a 7k RPM limit with stock/ported intake bigger exhaust cams want to push power to higher RPM.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 07-23-2010   #5
Pete
Pete,
Thanks for sharing your significant knowledge on cam selection. Without appearing to create a controversy, Marc H. does not recommend a cam upgrade for a 5.7L motor when porting heads. Why do you believe a stock displacement motor could gain (how much?) using Stage 2 intakes. Can you provide Lift/Dur on Stage 2's?
Thx
Old 07-24-2010   #6
Pete
Pete's Avatar
Pete,
Thx
Dom,as you know i have very high respect for Marc H. but recommending and choosing to do so are 2 different things.
I'll explain,not recommended could be a couple of reasons
1: idle quality some don't like the idle/sound of a camming car or for the price not worth the gains
2: some think bigger is better in a small cube motor i think there is a point where you can go overboard.
Stage II cam specs are .237 .440, i would not reccommend installing Stage II exhaust cams on a small cube motor you will loose too much low end power and driveability suffers what i would reccommend for exhaust with these are around 15 degrees less exhaust.
I will be trying Stage III intakes .242 .450 with Stage I exhaust cams .228 .415 i would like to go a bit smaller exhaust like a .224-.226 duration with a bit more lift .430-.450 we'll see what happens.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 07-24-2010   #7
Pete,
It'll be our little secret!
Old 07-25-2010   #8
scholtmj
scholtmj's Avatar
I will be trying Stage III intakes .242 .450 with Stage I exhaust cams .....we'll see what happens.
Pete
Very interested to see your results. Waiting to pull the trigger on replacement cams!
Interested in a set of Jeal intake cam paper weights?
Old 07-25-2010   #9
Pete
Pete's Avatar
Thanks,but already have a set of those paper weights.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 07-25-2010   #10
Pete,
SECRETS ARE GOOD
[IMG]http://i119.photobucket.com/albums/o128/wb9mcw/SIG-2.jpg[/IMG]
[IMG]http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif[/IMG]
[FONT="System"][SIZE="3"]"The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC
" We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln[/SIZE][/FONT]
