Old 12-22-2005   #1
ZR-1 Mack
ZR-1 Mack's Avatar
Default Which Oil Filter do you use?
As you can probably tell, I'm trying to get to 50 posts and just about out of ideas. Here's an easy way to get credit for another post.
Which oil filter do you use on your ZR-1?
I use the Bosch 3401 with the gloss black finish like the original Delco.
One filter that I would never use is the original Delco PF970C because of the problem Marc Haibeck found with the oil anti drain back valve.
For more info I posted the link under Product Reviews and evaluations.
ZR-1 Mack is offline   Reply With Quote
Old 12-22-2005   #2
Nick
Default Re: Which Oil Filter do you use?
I use the K&N HP2007. In my opinion probably the second best choice, behind the Mobil 1 filter, which I have found difficult to locate in my area.
Old 12-22-2005   #3
bobbyhi
bobbyhi's Avatar
Can you post the Mobile 1 filter number? Thanks.....
Old 12-22-2005   #4
Nick
A search of the ZR-1 Net Registry Archives reveals part number M1-207.
Old 12-22-2005   #5
91King
91King's Avatar
Mobil 1 filter for me.
If you can't find them locally you can get them from Mid America, Ecklers etc. I order mine a few at at time from Mid America.
91King is offline   Reply With Quote
Old 12-22-2005   #6
Mobil 1
or
Bosch
Old 12-22-2005   #7
Jeffvette
M1-207 for me
Old 12-22-2005   #8
ZR-1 Mack
ZR-1 Mack's Avatar
Nick...Don't know if there's an Auto Zone in your area but I had no problem buying either the Bosch or Mobil 1 right off the shelf.
Old 12-22-2005   #9
Aurora40
Aurora40's Avatar
I picked up a Bosch and a Mobil 1 at Autozone. The Bosch is currently on the car. I will try painting the Mobil 1 black and then probably just go with that in the future. But the Bosch seemed nice enough...
Old 12-22-2005   #10
ralph92ZR1
ralph92ZR1's Avatar
WIX Oil Filter is my choice because it was on the car when purchased and from a "Wix" product search.
ralph92ZR1 is offline   Reply With Quote
