Old 07-18-2010   #1
Jagdpanzer
Jagdpanzer's Avatar
Default Cylinder Head Secondary Shaft Bore Plugs
For the 402 LT5 stroker project I will be ditching the secondaries.
Turned out these aluminum pieces on the lathe to plug the shaft bores remaining in the cylinder heads. The plugs are slightly oversized, sealed with a dab of Loctite 462 and driven in with a hammer. Protruding part will be taken care of during porting. For the upper blind hole I drilled a small hole through the plug in order to vent the air trapped behind it as it was driven in.
Old 07-18-2010   #2
Default Re: Cylinder Head Secondary Shaft Bore Plugs
Are you an engineer/machinist or sumpthin?
Very nice Phil.
Old 07-18-2010   #3
Jagdpanzer
Jagdpanzer's Avatar
Thanks Jerry, I'm an engineer and picked up running machine tools while in the navy.
I now work for MAN Diesel & Turbo. http://www.mandieselturbo.com/0000002/Home.html
Old 07-19-2010   #4
I knew you were an engineer Phil, from our conversation in Alexandria last year. I was just funnin' with you.
Old 07-19-2010   #5
JThomas
JThomas's Avatar
Nice work Phil, looks like the beginning of a quality project!
Joe Thomas
Corvette Club of Michigan
NCRS-Michigan Chapter Member
NCM Master Ambassador
Former NCM Board Member
1991 ZR-1 Melon Copper Metallic/Black
1992 ZR-1 Bright Red/Black (Sold)
1995 ZR-1 Bright Aqua/Gray (Sold)
2012 ZR1 Super Sonic Blue / Dark Titanium
JThomas is offline   Reply With Quote
Old 07-19-2010   #6
Scrrem
Scrrem's Avatar
Phil, you are a true craftsman!!! Wish I could do that stuff with metal.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
