Old 07-18-2010   #1
rhipsher
rhipsher's Avatar
Default Rear rebushing #2
Now install it and take the next one out.
Then simply install the rear spring bushings.
Now I didn't replace the differential carrier bushings because Bill B. had warned me not to. Just keep it rubber. Plus they still looked good.
One thing that suprised me is that the kit did not come with front or rear sway bar bushings. Go figure. I checked my rear sway bar end link bushings. All that was left of any bushing that used to be there was a few crumbled pieces. In other words no bushing at all. I've got front and rear sway bar bushings on the way. Those are really easy to do.
Old 07-18-2010   #2
sammy
Default Re: Rear rebushing #2
what was the reason bill didnt want you to use the bushings for the rear batwing?????
Old 07-18-2010   #3
rhipsher
rhipsher's Avatar
He said polyueothane on them would be to stiff. I still might do it anyway when the sway bar stuff comes in just to see 4 myself. Also it involves removing the rear differential cover and I don't have the sealer to seal it back up at the moment.
