Old 07-17-2010   #1
Topfuel
Topfuel's Avatar
Default next part I need AC to line adapter
So I bought a rebuilt AC compressor and I need the adapter that has the 4 bolts that bolt to the compresser and the AC lines also nee that AC line just the aluminum line the hose can be bad since I will weld on my own hose ends.
http://www.whiteracingproducts.com/i...roducts_id=547 Here is a picture of the compressor and the angled adapter on that bolts on with 4 bolts is what I need
Topfuel is offline   Reply With Quote
Old 07-17-2010   #2
65ZR1
Default Re: next part I need AC to line adapter
This may help you out for the hoses. http://www.hotrodair.com/index.cfm/p...rod/prd111.htm
This way you can make your own.
65ZR1 is offline   Reply With Quote
Old 07-17-2010   #3
phrogs
phrogs's Avatar
ok I have the adaptor for the A/C becasue its an old compressor that I swaped because the bolt hole is striped, the one that the hoses are held in with.
Needs to be plug welded, drilled and taped
you interested in that as well?
JOHNNY P
Currently own
Old 07-18-2010   #4
Topfuel
Topfuel's Avatar
YES I can weld I think !! I want it ALL wait I mean yes I want the adapter and the cover. Do you have the hose that bolt to this also don't really need rubber hose just the bent tube
Old 07-18-2010   #5
phrogs
phrogs's Avatar
I do not have the AC hose I sold the ones I had last year.
I have the other AC hoses but not that main one.
they do pop up on the bay once in a while.
JOHNNY P
Currently own
Old 07-18-2010   #6
Topfuel
Topfuel's Avatar
Send me a paypal request or I can send you money for the aluminum cover and the ac compressor adapter so I can go fort on this project thanks my email will be sent to you on a PM
