Old 07-16-2010   #1
Alberta_ZR1
Default Any ideas on where they ran the satellite radio antenna cable!!
So I've had my Z for a few weeks now and I decided that I will try and track down the satellite radio antenna cable that had been installed by a previous owner at some point.
I have determined that this has to be one of the best installations I have ever seen. The antenna almost looks factory (if they had XM back in 93), it is spaced perfectly on the right side to mirror the power antenna on the left side.
I have spent two hours this evening trying to find the stupid cable. So far I have found an old CB antenna cable and antenna inside the rear fascia, and a spare key wired inside the frame, but no satellite radio antenna.
I have stripped the trunk, and the passenger side kick panel and carpet. I guess later this week-end I'll start on the drivers side and then down the center......
Laying underneath the car I can see the antenna base and the wire is there. Has anyone done a similar install, and if so, where did you run the wire?
PS: I can't ask the previous owner, because he didn't install it.
Alberta_ZR1 is offline   Reply With Quote
