Old 07-10-2010   #1
secondchance
Default Final touch
Roof panel trim piece arrived a couple of days ago. So, opened up the package and noticed 2 scuffed areas. Light sanding and dusted w/ Duplicolor satin black "trim" paint - a perfect match.
I brought the top into my living room and taped the edge, put 2x4 against the edge and started tapping with a hammer. While doing this I inadvertantly pushed a small table with 2 large wrought iron candle holder and these started to fall! I blocked it with my shoulder and head.
One of the holder hit my head and wife goes "it hit your head are you ok?".
I go "thank god it hit my head and not the shiny new top!".
Well, got the new trim on successfully with no damage - at least no damage to the top.
Old 07-10-2010   #2
secondchance
Default Re: Final touch
I am not sure but my wife might say "Thank god it hit your soft head other wise it might have damaged the candle holder if it hit the new top"
Ha, ha,... Good one!
Old 07-11-2010   #3
Yun, you are a True Believer!!!
I salute you!saluting
Old 07-11-2010   #4
secondchance
Tom,
Back in 93 when I lived in Orlando I got too wild and slammed my 91 Z side ways into a highway light pole (I-4 exit 50 ramp for those who are familiar w/ Lake Mary/Heathrow area).
It took Roger's Corvette (back then Tim worked for Roger) 3 months and $35000 to repair the car since Progressive wouldn't total the car. I broke my left collar bone but all I had to do was wear a collar sock and the bone healed by itself and before the car came back home - need I say more?
http://www.burkecorvettes.com/frame.htm
(all pics minus the top one is my 91).
http://www.burkecorvettes.com/gallery.htm
(bottom pic is mine before and after)
Later Roger says to me "this car is too much for you". I looked back at him with a grin - "No. I am too much for this car!".
Old 07-11-2010   #5
Scrrem
Scrrem's Avatar
Now that's a car guy's women!!
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 07-11-2010   #6
Look forward to seeing it!
Old 07-11-2010   #7
secondchance
David,
I put the filler on your console piece.
Once dry, 1000 grit wet sanding and time to spray. Duplicolor trim satin black is too black and too shiny. I got to pick up a can of Badger airbrush propellant and use satin black toned down with grey primer - flatter and less black.
