06-30-2010 | #1 |
Fidanza Flywheel what Clutch ??
Hello i have a 92 ZR1 and want to install so what is the right Clutch for the Vett to use the Vett on the Roada Fidanza Flywheel some tell me the tell me to use a special Slave cylinder and a Clutch from DRM Clutch kit from the Camaro is the best and a old Friend i ask at DRM but get now answer so please let me know when you have anny information wfg Jochen
1992 Corvette ZR1 Polo Green ll 382 |
06-30-2010 | #2 | |
Re: Fidanza Flywheel what Clutch ??
1995 Convertible Supercharged Auto 1974 454 550hp (avatar car) On the blocks- -Scharger install ! 1992-Zr-1 Sold. Watson Headers Ported Plenum, Housings Random tech cats Fidanza Flywheel Chipped, Relocated Mat Woods 165 stat Borlas, Straights 1996 Lt4 Sold 1994 Lt1 Sold 2004 Z06 Sold AKA** Illenema |
06-30-2010 | #3 |
If it's going to be a daily driver, don't go too aggressive, I instaled a stage II SPEC clutch with a Fidanza and it's a bit harsh upon engagement, not street friendly. Took me some getting use to but love it at the strip. I was told my a member recently that the Center Force clutches are awsome and engagement is smooth as glass.
Rich
06-30-2010 | #4 |
Jochen I've had two different clutches with the Fidanza. The first was the stock clutch/preasure plate with a centerforce sprung hub disk which I liked. Now I have a Spec stage 3+ with the Fidanza which I like even more. The Stage 3 is different than the Stage 3+. The 3+ is a full face disk unlike the puck disign in the stage 3 so the 3+ engages just like the stock one does but has clamping force for up to 800hp.
07-01-2010 | #5 |
I used a stock pressure plate and a Stage 2 disc from Carolina Clutch. over 4,000 miles now and no problems. I like it.
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I] [I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I] [FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT] [I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B]) 1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I] |
07-01-2010 | #6 |
Thanks a lot for the answers
so i hope i will finde the right one thanks a lot from Austria wfg Jochen
07-01-2010 | #7 | |
rphipsher, Is that a sprung hub? What about the rattle can noise from the trans? |
07-01-2010 | #8 | |
And I can tell you it works great with very little rattle. And you can ask FULLPWR and USAFPILOT. They've both been in my car and can vouch for how little rattle they hear. |
08-05-2010 | #9 |
sorry for my uncnown
te tell me all fix clutch will rattle and the clutch wit the spring are not what do you think thanks a lot Jochen
08-05-2010 | #10 |
