Old 06-29-2010   #1
mimzr1
mimzr1's Avatar
Default Belt tensioner going bad?
Hello All,
My accessory drive belt is starting to wear or fray badly on one side, the
side closest to the radiator. I have a replacement belt. Should I replace the
belt tensioner pulley as well? Thanks!
-Mim
'93 40th Anniversary #438
77K miles
mimzr1 is offline   Reply With Quote
Old 06-29-2010   #2
sammy
Default Re: Belt tensioner going bad?
i would ck to see if the tensioner pulley turns without wobbling,if it doesnt wobble and turns freely i dont think its a problem . at least thats what i checked when i put randys pulleys on my car
Old 06-29-2010   #3
bdw18_123
Also, make sure that the pulley isn't cracked or worn in a weird way where the belt contacts it.
Old 07-02-2010   #4
BlackWidow#2
BlackWidow#2's Avatar
Hi Mim, I hope you are soon cruising in tip top shape.
Best regards, George
BlackWidow#2 is offline   Reply With Quote
Old 07-08-2010   #5
Well, the tensioner is but one pully that could be cockeyed enough to cause that. If you don't see anything wrong, take the belt off and see if there are other pulleys that wobble. And, verify all accesory bolts are in place and are not loose.
If in fact your tensioner pully is bad, and a ZR-1 pully can't be found, I can attest that an LT1 pulley works just fine.
Good luck!
P.
Old 07-10-2010   #6
Zr1 Destroyer
Zr1 Destroyer's Avatar
Autozone has the pulley in stock and it's around $10 if I remember right.
Zr1 Destroyer is offline   Reply With Quote
