![]() Join Date: Feb 2009
I am considering a set of drag radials for my 90. What are the better performing ones out there?
Rich
i have used the mikey thompson drag radial 315x35x17 and the new nitto nto5 drag radial and the nitto is about a tenth better off the launch (60 ft ) best i could do with the mkey was 1.81 with the nitto my best after only 6 runs is 1.69 .the nitto will not last as long but if you put them on at home and drive to the track the nittos are way more stable . plus you can run the nitto tire pressure between 21-25 at the track where the mikey i had to run 15 lbs ,and the car liked to scate at the top end .kinda like a fat girl that struted her stuff
Thanks Sammy!!! Thanks what I was looking for
![]() Rich
![]() Join Date: Aug 2008
I have a set of 275 40 MT's and they grab hard. But you have to heat them up good.
#6 | |
Rich
#7 | |
Rich
Just as an alternative, at the last drag day, Mike was hooking fine on Kuhmo Ecsta XS tires. He has the same mods as me, plus 4.10's. I had a lot of trouble with traction on GS-D3's, by comparison.
Unlike DRs, you could drive on these regularly. They obviously won't tolerate as hard launches as DRs, but it might depend on what you are looking for. Last edited by Aurora40; 06-28-2010 at 08:00 PM. |
