06-26-2010 | #1 |
90-93 Seat Mod - its Comfy Now
One of the few things I do not like about my 90 are the seats. They just have too much give in the seat bottom and I feel like I am squeezed between the bolsters (and I am not a heavy guy). It is particularily anoying trying to get out of the car if you are parked fairly close to another car and have to be careful with the door. Its like sitting in quicksand - you try to get out and you are almost glued into the seat.
I know a few people have added a piece of plywood to the bottom, so I did that. It helped with the bolsters being too tight and getting in/out - but it now fellt a bit like a park bench. So, I finally found a good use for a yoga matt (they're about as common here as pickup trucks are on the prairies). They are made of relativelly firm foam rubber, about 3/8 inch thick. I chopped one up and added 3 layers of yoga matt on top of the plywood. Its just perfect now.
[SIGPIC][/SIGPIC] __________________ 1990 Corvette ZR-1 #2824 4.10's, Custom PROM, Flowmaster, Top End Port NCRS BC Chapter Last edited by gbmidyear66; 06-27-2010 at 01:59 AM. |
06-26-2010 | #2 |
Re: 90-93 Seat Mod - its Comfy Now
Good idea!
06-26-2010 | #3 |
While I was rebuilding the lumbar air pumps I noticed that the seats only had two of the support straps yet there were hook up sites for three straps (as you can see in your first pic) so I bought all new straps and got extras so seats now have three straps....that made a BIG difference>>>
Michael :cheers: [I][SIZE="2"]1990 RED on RED #566[/SIZE][/I] [I][SIZE="2"]WAZOO MEMBER[/I][/SIZE] |
06-26-2010 | #4 |
Where did you buy the straps?
06-26-2010 | #5 |
http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000050f~Z5Z5Z5ABXPK~ P29.95~~~~S2YV0WKFBJ71191213350g~Z5Z5Z5~Z5Z5Z50000 050F
or http://www.mamotorworks.com/corvette-3-52-7078.html
06-26-2010 | #6 |
Also, I found that the '90 seat bottom straps tend to be not nearly as tight as say the '93 straps. I got a hold of a set of straps from a '93, they are white with black rubber lines on them, the '90 ones are all black/brownish. The '93 ones are much tighter elastic than the '90 ones, my '90 seats now are as comfortable as the ones in the '93. The seats in the '93 C4 I had (non-sport seats) were really comfortable, I could take long trips with no problem. I am 6'2" and 170 lbs though.
I'm not sure when they switched to the white, tighter style elastic so I don't know what the '91 & '92 cars have.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B] 1990 Corvette ZR-1 [/B][I] White/Flame Red, #2299, mostly stock, 144K miles.[/I] -Cams timed to the '93-'95 405HP LT5 stock timing. -IAT sensor relocated to below front bumper. -Haibeck hoops installed in airduct. -OBX cat-back exhaust. [COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR] 1993 Corvette Coupe Black/Black, 6-speed (SOLD - October 2009 :hello:) |
06-26-2010 | #7 |
Michael where did you get the new connectors????
06-26-2010 | #8 |
Need to clarify.... I rebuilt both air pumps and have in my ZR-1 parts bin but I went ahead and ordered the replacement pumps which came with the connectors etc. Down side these suckers are pricey at ~$140 per pump/piping/connectors but up side everything now works.
http://www.mamotorworks.com/corvette-3-52-6084.html
06-27-2010 | #9 |
Interesting Michael.
I thought I had read somewhere that adding another Trapeze strap didn't change things much, guess that is not so. Will pick up a couple more and add one to the pass seat - then I can compare the two solutions.
[SIGPIC][/SIGPIC] __________________ 1990 Corvette ZR-1 #2824 4.10's, Custom PROM, Flowmaster, Top End Port NCRS BC Chapter |
06-27-2010 | #10 |
looks like you coulda used 4 straps
