06-21-2010 | #1 |
cooling fan ralay
06-21-2010 | #2 |
Re: cooling fan ralay
Measure the coil resistances, and if they are the same, try it.
These relays hardly ever fail - what problem are you trying to fix?
06-22-2010 | #3 |
few times just one ventilator start cooling radiator other one after few seconds stop ...., I check wires , connectors etc ... but I didnt get time to
change relays to see if they are both ok. Now both runs fine. I Just want to buy relay in case that is reason for my cooling trouble as a spare part because every time when I shopping oversea takes me 14 -20 days before i get stuff here. I do have Marc H. chip with cooling modification. |
