Old 06-19-2010   #1
Jagdpanzer
Jagdpanzer's Avatar
Default WTB Later Style Throwout Bearing & Retainer Ring
Looking for a new or good condition used later style 93-95 throwout bearing (with the plastic insert) and retainer ring.
The one I was running broke off one of the retainer tabs wihich allowed the retainer ring to fly off and rattle around in the bellhousing until became hung up on the clutch fork.
Old 06-21-2010   #2
zrwhat
zrwhat's Avatar
Default Re: WTB Later Style Throwout Bearing & Retainer Ring
Phil,
I've got a new style release bearing for 93 on up, got it with my new LUK clutch set up.
I'm not ready for my install just yet so if you need one to get you going again, take mine and replace it when you can.
Best I can do right now,
Gibby
703 999-8471
zrwhat is offline   Reply With Quote
Old 06-21-2010   #3
Jagdpanzer
Jagdpanzer's Avatar
Thanks for the offer Gibby.
In the mean time I borrowed the the throwout bearing from the Center Force clutch set I had on the shelf for the LT5 stroker project to get me by for now.
I still would like to have a spare handy though. Perhaps I can replace the broken tab plate on the one I have now from a earlier style throwout bearing if they are of the same design. With luck there might be a good used one laying around in the WAZOO parts bin given the clutch replacements that have been done over at Jim's garage in the last year.
Old 06-21-2010   #4
Scrrem
Scrrem's Avatar
Phil,
I have my old throwout bearing assembly from my old clutch. Your welcome to it if you want to compare the two.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
