Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 06-17-2010   #1
LORDVDR
Default Air conditioner
Anyone know how to recharge the air conditioner? Mine is just blowing hot air. (insert joke here).
LORDVDR
Steve Miller
[URL="http://www.Alive-N-Kickin.net"]www.Alive-N-Kickin.net[/URL][SIGPIC][/SIGPIC]
LORDVDR is offline   Reply With Quote
Old 06-17-2010   #2
Scrrem
Scrrem's Avatar
Default Re: Air conditioner
Steve,
I have the same thing happen to me on my way back from BG. I had to pull the code from the CCM and it was a code 9 which was low freon. When the system is low on freon, the compressor is shut down. I had to pull the neg battery cable to reset the code and added my last can of freon, its better, but needs more. I need to take mine in to get another can added.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 06-17-2010   #3
Aurora40
Aurora40's Avatar
To add freon, you hook a can of it up to the low-pressure side and turn the A/C on. It helps a lot to dunk the can in a bucket of water, or even wrap a wet towel around it, because it cools down very quickly which lowers the can pressure, and it will take forever to transfer the freon from the can to the system.
However, you may want to troubleshoot before just adding freon, to make sure that is the problem. Pressure gauges will tell you if the pressure is in the ballpark of full, and if it's enough that the compressor should cycle on. Then you can see if the compressor actually cycles on when the A/C is turned on.
Bob Saveland
Former owner of #2517
Old 07-15-2010   #4
Paul Prisaznuk
Are you installing R-12 or converting to R-134a? Either way there are challenges. Any notes on your experience will be appriciated. RPO ZR1. Maryland
Paul Prisaznuk is offline   Reply With Quote
Old 07-15-2010   #5
QB93Z
QB93Z's Avatar
Hi Paul, welcome to the ZR-1 Net Registry. I replaced the compressor in my 1993 ZR-1 two years ago and maintained the R-12 system. No problems until last week when it started blowing the fuse for the AC compressor clutch.
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
