06-16-2010 | #1 |
Replacing tie rods.
I just got done replacing the inner and outer tie rod ends hoping that would have an impact on my front end vibration coming through the steering wheel thats been slowly getting worse over the years. Replacing both inner and outer tie rod ends instantly cut down on the vibration by at least 60%. I also have the whole poly bushing kit on the way.
The outter ones are easy but when I got ready to unscrew the inners from the steering rack I thought now how in the f@$k am I going to get a wrench in there to unscrew them? Even took the sway bar off for more access. So I go to Oreillys to buy a small pipe wrench. I figure since the wrench flats are not facing the only spot a wrench might fit that with a pipe wrench it won't matter. When I walk up to the counter to pay for it I lay the inner tie rod on the table next to it. And the guy says "You know we have a tool for that right?" I said dude! Hook me up. That inner tie rod end wrench worked like a charm. Moral of the story. If it looks impossible to get off! They probably make a special tool for it. |
06-17-2010 | #2 |
Re: Replacing tie rods.
Hey photos of the tool and even a mock up of the actual repair would be nice for Dynomite who is documenting things just like this with links to the forum posts on just such topics.
See here >>> http://www.zr1.net/forum/showthread.php?t=11619
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif "The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC " We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln |
06-17-2010 | #3 |
This is what it looks like. http://www.nextag.com/norob/PtitleSe...itle=511844728
This is the one I used http://www.sportsmansguide.com/net/c....aspx?a=599073 |
06-18-2010 | #4 |
OK good info we are half way there now.
Next time you have the Z in the air (or if the rods are still off just do a bench photo) take a pic of the inner tie rod ends and maybe hold your special tool up to show how it fit nice and made the job easy. Post the pics here..... Then we will PM Dyno and have him add this post to his list.
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif "The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC " We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln Last edited by WB9MCW; 06-18-2010 at 02:22 AM. |
06-18-2010 | #5 |
I know but as much as it might help somebody sometimes I like to just get it done without making a documentery of it. But in a nutshell here it goes.
1. Jack front of car up. 2. Remove tires. 3. Remove brake calipers and disks for access to tie rod ends. 4. Remove swaybar. 5. Stick tie rod seperator/fork between wheel spindle and rod end and with a 3lb sledge hammer give it 2 or 3 good whacks and "Boing" We be seperated. 6. Remove boot clips from inner tie rod ends. Then pull boot out and push back white plastic protector to expose wrench flats. 7. Then use inner tie rod end wrench with a 1/2 drive flex bar and in a CCW direction unscrew. 8. The rest is just the reverse. 70 ft lbs is the recomended torque for inner tie rods. I'll add pictures of the inner rods tonight or tommarrow |
06-18-2010 | #6 | |
What vibration I am not sure but I am assuming wheels are a bit out of balance rhipsher.......thanks for the information If you are adding some pictures just insert them in your first post so all your information is right up front Last edited by Dynomite; 06-18-2010 at 05:00 PM. |
06-18-2010 | #7 | |
