![]() Join Date: Feb 2006
Guys,
Can a new 93z eprom be put into a 90z without a potential harm? pn on the box is: 12528772 Just wanting to swap it to ck for differences. |
What differences are you wanting to check for? You can take the settings and transfer them to the 90 calibration, but not plug a 93 calibration into a 90 ECM. ECMs are backward compatible so you can run a 93 cal in a 90 using the corresponding 93 ECM but not vice versa.
![]() Join Date: Dec 2004
http://zr1netregistry.com/ZR1_parts.htm
Okay Luis this a a link to our cross reference chart of our ECM's and PROM's , and I don't find that P/N you listed, unless I missed it? The both of them should have P/N's printed on them. The ECM has a white sticker usually on the top and the EPROM's have either black or blue printing on on the metal heat sink/shield. I have a spare EPROM, AUAH, it's my OE Prom from my 90. I could send it to you to try? I also have a spare ECM if needs be. The only thing I'm sure of with EPROM's is that a 90 chip needs to be in a 90 ZR-1, but I ain't real up on this stuff. ![]() ![]() Tom
![]() Join Date: May 2005
Uncontrolled Curiousity
![]() I had bought a new 93z ecm & prom last year for future need. although my z is a 90, I just couldnt pass it up at the price, He hooked me up. with everyones help, and everything we've tested and changed so far, we pretty much boiled it down to Injector issues. I'm taking it to Corey soon for the injector fix,headers,tune. just kinda hard to hear your Z whining in the garage cuz it wants to be fixed and that ecm& prom just sitting in a box taunting me.. day in...dayout ![]() Really, was hoping if it could be put in it..just maybe it would make it that much better .....still taking it to Corey even if it were to run better. I know that ecm issues would prompt other symptoms, codes ect..I'm not that far into grasping all the diagnostic tech relation stuff, i'm kinda of a part swapper ![]() Thanks for the info from everyone, now I know what I can do and cant. (put in 93ecm w-90 chip only) Thanks Guys!! ![]() Luis oh, Tom, Ricks bringing me his 90chip to check out, thank you !!!! for your offer to lend me yours. ![]() |
![]() Join Date: Jul 2005
Hello all
I am looking for a stock EPROM/Chip for a 1994 ZR-1. Does anybody know where I can find one? Sam |
I can borrow to you one .
Jano |
#9 |
![]() Sam, I still need to fix my z, but as soon as I do and dont need the 93 prom as mentioned in this thread, I wouldnt mind selling it to you at all. Thing is, it may be a little while before I take it to Corey's and determine if I would even have to or able to use it with my 90. I know its not a definite, and timing not right for you but just wanted to offer it. ![]() Luis |
#10 | |
Sam |
