Old 06-15-2010   #1
Arrow Strange Leak
I had the car out the other night (91) and ran it out pretty good. Last night I noticed a puddle of water on the garage floor. Cleaned it up, but it's back again this morning!
I haven't investigated further -- thought I'd get some ideas before diving in. As you can see, the leak is coming from the drain hole behind the psg door. It hasn't seen rain or water of any kind so I'm assuming maybe it's the radiator?
Puzzling why it would be draining there...any thoughts would be appreciated!
Thanks,
Old 06-15-2010   #2
pantera1683
Default Re: Strange Leak
Thanks,
From the color, I say it's your windshield washer fluid leaking; probably a hose from the reservoir.
pantera1683 is offline   Reply With Quote
Old 06-15-2010   #3
On the passenger side so it's one of two things. The windshield washer fluid reservoir or the drain tube condensation from the AC. Both leak from about the same area (the firewall front of door)
I concur with the blue statement above as to what it probably is.
Old 06-15-2010   #4
The windshield washer fluid would make more sense...I'll check it out!
Many thanks!
Old 06-15-2010   #5
pantera1683
I concur with the blue stement above as to what it probably is.
Yeah, condensation would be clear water.
Old 06-15-2010   #6
Concur !
Old 06-15-2010   #7
Most likely washer fluid or whatever drained into the rocker panel and out the back behind the door.
