Old 06-13-2010   #1
Default ZR-1 Block Numbers
Not sure if these are posted or not...
ZR-1 Block #s
10090511...350.....90....2...LT-5, ZR1 Vette, 375hp
10153558...350...91-92...4...LT-5, ZR1 Vette, 375hp
10199001...350...93-95...4...LT-5, ZR1 Vette, 405hp
LGAFF is online now   Reply With Quote
Old 06-13-2010   #2
Default Re: ZR-1 Block Numbers
I thought this might help in decoding Dominic's block, but I did not find this referenced on the spare block that I have.
It has 10ZSH 91100015 on the side.
I did notice on the front drivers side it is numbered with 1059...I am wondering if this is the sequence of LT-5s built...the car is # 702 so its possible.
Old 06-13-2010   #3
Lee,
Maybe Gordon Killebrew could be of help on this.
Didn't my block have the 9001 number?
Old 06-13-2010   #4
Found it, the 90 actually has a 91 block stamp 10153558
Also Block and Girdle are mated with the same stamped # 1059
Old 06-14-2010   #5
1989ZR1#74
10ZSH 91100015 ??
10ZSH: 1990 MY 375HP/350CI, Manual Transmission Electronic A/C
91100015 is short 2 digits. Are you sure that's the number?
It should start with an X for MM Stilwater
last 4 are that days sequence, but the date derivative can't be right.
So should look something like this:
X911100015:
X = MM
9 = 1989
11 = November
10 = 10th
0015 = 15th LT5 assembled that day.
Eric
1989 ZR-1 #04 Pilot, Advertising/PR Campbell-Ewald S9YKH1
1989 ZR-1 #58 LT5 only
1989 ZR-1 #74 Unreleased Production / PR Dept 9PR110
NCRS #3,182 SACC #2,420
Member Corvette Museum
Corvette Forum: "ewjxn"
2009, 2010 Gathering Attendee
1989ZR1#74 is offline   Reply With Quote
Old 06-14-2010   #6
I will look, does your motor have matching stamps on the block and girdle?
Date Stamp from #702
Old 06-14-2010   #7
1989ZR1#74
This LT5 came from the 702nd 1990 built. It's VIN is: 1G1YZ23J8L5800702
It is/was a Black/Black
It's block casting date was Tuesday 10/03/1989. Unlike non LT5s that have raised cast in dates the LT5 casting date is "stamped" into the block. This number will supesede the date on the "oil pan" boss.
Old 06-14-2010   #8
So
10ZAA X 206170003
Is this an LT-5 produced on 6/17/1992 and the third motor produced?
This is Dominics motor.....VIN stamp area does not match the car
This is the stamp were the VIN traditionally is
100991 14
Old 06-14-2010   #9
Eric870
Eric870's Avatar
My 1990 #740, the motor was built on 11/20/89 5th motor of the day.10ZSHX911200005
Question: My Build Sheet Date of my car is 89/321. Does that = 11/16/89? That is 4 day before my motor was built.
Eric870 is offline   Reply With Quote
Old 06-14-2010   #10
bdw18_123
More LT5 stamp weirdness? My '90 ZR-1 LT5 re-stampings are still a mystery also.
Here is a recap of mine:
#2299, MM LT5 number re-stamp:
VIN cross-out & block casting date (passenger side of engine):
VIN stamp (driver side of engine):
Invoice for the car has 5/22/90 as the "PRICED" date, which I think is supposed to be the build date? And 11/22/90 is when the car was delivered to the original buyer.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
