Old 06-11-2010   #1
DaveK
Default Wheel house body panel screw/bolt
I noticed I have lost one of the screws holding the wheel house to the hood. Anyone know the spec on these and if they're available?
Thanks
Dave
1991 #1516 Black/Black
davidmkelly.com
Author of fast-paced, sci-fi thrillers.
Old 06-11-2010   #2
jrd1990zr1
jrd1990zr1's Avatar
Default Re: Wheel house body panel screw/bolt
There should be a number of them on the upper wheel housing. I think Corvette central carries them. Try CC # 20002 $1.25 each
Old 06-11-2010   #3
DaveK
Thanks I dont find anything on that CC# though
davidmkelly.com
Old 06-11-2010   #4
Marq21
COrvette Central sells them in packs of five. They had an Ebay listing for these just a day or so ago. They might not come up under a ZR-1 search. Try "90 - 91 Corvette" -- that will probably get a hit.
Troy Marquis
68 L-89 #9876 - Under Restoration
69 L-88 #21214 - L-88 Tribute
70 L-46 #9516 - Top Flight
71 LT-1 #2638
71 LT-1 #5172 - Canadian Export - Top Flight
71 LS-6 #15133 - Canadian Export - Under Restoration
90 ZR-1 #338 - Restored
90 ZR-1 #890 Project Phoenix
91 ZR-1 #1255 - Triple Crown Winner
69 Firebird Project: w/ 69 L-89 Motor #24390
16 Z06 Admiral Blue/Red Interior (1 of 2) - Sold
Marq21 is offline   Reply With Quote
Old 06-11-2010   #5
DaveK
The closest I seem to be able to find are "TORX BODY SCREW - WITH WASHER - SET OF 5" Part #344032. Are those the ones?
davidmkelly.com
Old 06-12-2010   #6
I'm not 100% sure on this but I think those are the same as the screws that hold the wheel house inner panels in place.
Pull one of each out and do a camparo.
Old 06-12-2010   #7
gbrtng
gbrtng's Avatar
Check your rear tires (just kidding).
Old 06-12-2010   #8
jrd1990zr1
jrd1990zr1's Avatar
My mistake, I was looking at an Eckler's C-4 2010 catalog, right side of page #109.
Sorry, John
Old 06-12-2010   #9
Marq21
These Torx screws are the large screws that is used in the wheel wells.
Troy
Troy Marquis
71 LT-1 #2638
